4.9 Liter Oil Analysis
Just got my oil report back from Blackstone.
Model: 1990 F150
Miles on Oil: 1475 (5 months)
Miles on Unit: 146,000
Oil Filter: Wix
Air filter: Wix
We've put a "?" in the anti-freeze field, but unless your oil sample could have gotten contaminated outside the engine, we think the potassium and sodium show minor anti-freeze in the oil, seeping from the cooling system. Your oil wasn't in use many miles and wear was low. Aluminum though, was higher than expected compared to the levels for the other wear elements. Aluminum
normally comes from pistons so the coolant seep may be at the upper cylinder area of the engine. Suggest a cooling system pressure check. Note fuel dilution too.
ALUMINUM--4
CHROMIUM--2
IRON--8
COPPER--3
LEAD--4
TIN--0
MOLYBDENUM--5
NICKEL--0
MANGANESE--0
SILVER--0
TITANIUM--0
POTASSIUM--81
BORON--10
SILICON--13
SODIUM--20
CALCIUM--2217
MAGNESIUM--40
PHOSPHORUS--852
ZINC--985
BARIUM--1
Fuel--2.0
H20---0
Glycol--?
SUS VIS @210F 56.8
Insoulubles--0.3
I don't drive it much anymore. Mostly for hauling or driving in the fields. I usually change the oil at 3000 or 6 months, but changed this early since it was jet black and never looked like that before. I am concerned about the antifreeze. I do notice that it looses a little. I wanted to think that it was leaking, but I never smelled it. I can drive on the highway up north and don't loose any, but short trips and it goes down. I add around a pint every few months so it isn't much. I suppose it is the head gasket? I will do a pressure check.
I am positive I did not contaminate the sample. I guess that is not good.
I am driving it on a trip with the canoe in a week. Anyone think that would be a problem? Also, would this cause pinging. I drove up north with the boat right after I changed it and had to use premium gas so it wouldn't ping.
Model: 1990 F150
Oil Filter: Wix
Air filter: Wix
ALUMINUM--4
CHROMIUM--2
IRON--8
COPPER--3
LEAD--4
TIN--0
MOLYBDENUM--5
NICKEL--0
MANGANESE--0
SILVER--0
TITANIUM--0
POTASSIUM--81
BORON--10
SILICON--13
SODIUM--20
CALCIUM--2217
MAGNESIUM--40
PHOSPHORUS--852
ZINC--985
BARIUM--1
Fuel--2.0
H20---0
Glycol--?
SUS VIS @210F 56.8
Insoulubles--0.3
Thanks for posting your UOA! You've already found your way over to my related thread, which this kinda helps. Means that I won't need to run a Durablend UOA if Valvoline pulls ahead and is the 2nd oil to get run. End up doing Maxlife or Synpower...probably Maxlife since Mobil 1 will be providing me with the full-synthetic UOA.
Just wanted to say thanks.
SixStringMadness
09-22-2018 02:19 PM
TallPaul
Oil & Lubrication
04-01-2004 09:17 AM
horsepuller
Oil & Lubrication
07-16-2003 01:05 PM
