99 Ford Explorer Sport 4x4 that 'sqeals' or 'whines'
Guest
Posts: n/a
As the temperature is dropping(30 degrees) this year I notice that in the morning or after a large period of inactivity the Explorer makes a high pitch whinning noise for about 1 minute or two of driving. Applyring the brakes (emergency or normal) does not increase or decrease the noise. The only this that affects the noise is the speed of the vehicle. I hope it is not a bearing... Does anyone have an idea
Listen Gents; that 'seal' needs to be replaced properly. The forth pair I had installed (4 times)was installed by a 'pro.' He packed the seal in grease, not too much, just enough that it DOES not squeal anymore. The very short term solution is to put the plastic tube on your WD-40 and give the area where the axle goes through the hub a shot. DO NOT GET any brake parts wet with oil DUH! It will help until it wears out or washes out. Best bet get them replaced....
