Hard start
Well, first of all - Welcome Aboard!
Glad to have you hear and hope you stay a while!
Honestly, that's ALMOST normal on our trucks, but your truck not starting every morning on the first try is odd. Does it make any kind of strange noise when turning over? I was thinking maybe the starter, but it actually sounds like maybe it's fuel related. Like your truck is not getting enough of a kick to start...but once you turn it over once, it is ready or something.
I have a 2003 and it won't start at the first try about once a week or so. Stick around, you'll get your answer.
Its not the starter. Turns over fine. Just coughs and sputters. If I pump the accelerator, it will keep going, smooth out and run fine. The motor only has 69,000 miles on it. Its annoying but maybe normal??
I should also note that an extended time at a stoplight will result in rough idle. Does that help the diagnosis?
How is your coolant level? Have you had to add any lately? I hope this does not apply to you but read this website anyway;
www.leakingfords.com
Originally Posted by homer4.2
Brian- Do those need to be changed at 50K? JW while we are on that topic because mine is at 43K! Go along with reastep!
I tried Crazy001's suggestion, but not much help. What I have done is give it a couple of seconds after turning on the ignition, then pressing the accelerator down maybe a third, then starting. Starts o.k., but I'm not satisfied. Shouldn't have to do this, in my opinion. Guess I'll try plug wires.
