SVO Heads
SVO Heads
Greetings,
I own a 90 Ranger 2.9L 4x4 and I am looking for a set of SVO Heads for my V6.
I dont know where to look for the very elusive heads...I am also looking for a header kit for the same engine...any suggestions would be and will be greatly appreciated.
P.S. aprox on cost of above mentioned items.
Thank You Librac23
Thank You Librac23
on
They are available mail-order from several of the large catalog companies, hold on and I'll find the link. -TD
OK, here's one from Summit:
http://store.summitracing.com/default.asp?target=edepartment.asp&N=120+429492523 2&x=12&y=7
on
Yes, it's a very common swap, there are motor mounts and headers available from many different sources. Planning a 5.0 swap onto mine, looking for an engine right now. Here's some more links with some info:
http://www.mercuranger.com/
http://www.v8-ranger.com/index.shtml
http://www.jamesduff.com/broncoII/v8conversion.html
As far as tricking out the 2.9 goes, there isn't a whole lot of bolt-on stuff available, you would have to tear into it and do some basic hi-po machining mods, and for the money you might as well swap in a 4.0 or V8. -TD
Thank you again TD...this info will help greatly. you have given me other options to explore...
The 289 that I have came out of a 67 For Galaxy..would have been nice to rebult that car but it sat on the ground for too many yrs and the frame.....well was considerably rotted...so my Dad and I pulled the motor and the Trans....impressively the tail seal is in perfect condition..the yoke from the Driveshaft came out still Shiny and the fluid is and still...Bright red...although the engine oil looked like Choclate syrup...
The Motor was carb fed...and I would like to retain the Fuel Injection...I know I will need to replace the stock computer..but they dont make a puter for a 289...so would the puter for a 302 work in its place? and I was planing on using a Painless wiring harness...so all of my own Old stock harness will have to go right?
well...thanks again..you have helped me out greatly
Librac23 90 Ford Ranger EXT cab
