Wind noise-FX4
Wind noise-FX4
I have an 04' FX4 and at speeds 65 and above there is a rattling wind noise in the A-post driver side along windshield or door frame. Its obvious wind is causing it, just cant figure out exactly where source of the problem is coming from- looking for ideas on a solution or similar problem ? Thanks.
put a piece of 2inch masking tape over the door frame onto the glass and drive if no noise that is the area if there is a noise take that tape off and put a piece on the door to the windshield pillar and drive if that is the noise stop rolldown the window put your lt knee against the door and pull in on the front corner of the door frame that will bring the door closer it might take a couple of times to get it right i know it sounds hoky but that is the way you do it
