F350 Headlights
I'm not 100% sure... but on my old 94 150, the headlights are separate from the directionals (this I know is true for yours, as I have a 2000 F250) However, if you wanted to purchase the other headlights - I assume you're describe the sealed housing headlights that come through on the work trucks - then you would also need to purchase the headlight "doors" that is, the trim that goes around the composite housings. As far as mounting locations being the same, I've no idea... Hope this was of some help... *shrug* Hopefully someone who works at ford will chime in for you
