Removing Exhaust System
I have a '98 F-150, 2x4, and I am trying to remove the exhaust system after the cat. I have taken off the U bracket on the joint, but I still cannot seem to slip it off. Anybody have any suggestions, I really don't want to have to do any hacksawing as I would like to be able to put it back together.
Keep in mind that the muffler clamp has made an indentation into the pipe you are trying to remove from the outer pipe.That indentation will have to travel the diameter of the outer pipe,that is still round,thus meaning you gonna need a big ole hammer to help it out,or cut it before where the clamp was.Good luck!
