Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-29-2004, 11:03 PM
xltcrunch xltcrunch is offline
Garage is empty, add now
xltcrunch is starting off with a positive reputation.
need antenna for am/fm/cb e-150
have an 87 e-150 conversion van.has an antenna on side of passenger side front fender. serves as antenna for am/fm & cb radios.cannot locate one anywhere. mine is broken. anyone know of where to find one? thanks
  #2 (permalink)
Old 07-29-2004, 11:13 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
Okay, replace it with a standard am/fm antenna, and then put on a seperate antenna for the CB and match it properly. If you don't you can damage your CB.
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #3 (permalink)
Old 07-30-2004, 09:42 AM
antenna fix reply to pfogle
thanks for the possible fix on my antenna, but i don't want to punch any new holes in my van if i don't have to.
the present antenna uses two holes in the side of the fender. if, i go the route that you suggested then i'll have two additional holes plus i'll also have two antennas sticking up. i guess it might be one possible solution, but i just don't know why i seem to have an antenna that no one has ever seen before.
it apparently came from the factory, maybe the conversion company, that way. thanks
  #4 (permalink)
Old 07-30-2004, 04:07 PM
pfogle's Avatar
patfogle DaPocky
The one on the fender is a factory antenna, or should be.... It may have had an aftermarket mast on it. You can replace that antenna with any factory ford antenna from a junk yard, and then get a magnet mount CB antenna.
__________________
Tags
150, 1968, 2007, amfm, anntenna, antenna, cb, conversion, e150, ford, fordtruckcbantennamasts, replace, replacing, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
