1988 E350 Computer Location & Removal?
wiring up '82 motor with '88 system
Hi,........
I was wondering & assuming that you have or are gonna switch your ignition &/or charging wiring since you have pulled your computer out. I have an '88 E- 350 also, & have pulled the 351 F/I out & put a '82 rebuilt 351 carbureted in. And was wondering if you could give me tips on how to wire up the '82 with the '88 wiring??.........I would REALLY appreciate your response.
Thanks,
diehard_ford man
Thanks,
diehard_ford man
removing ECM
That information might be handy for the next person who has to face this challenge.
Especially in a situation where time is important.
Inside under the heater box, there's a screw that holds a ground strap to the plastic holder for the ECM. Remove that second. Keep track of the ground strap.
Removing the cover over the heater box helps make the area easier to work.
The ECM may have several part numbers on it. Some are OEM and one is the manufacturer part number (usually the longest) Most likely, you will order a refurbished unit with a return core.
When assembling, make sure the ground strap is lined up with the screw on the plug going through the firewall.
Correct Manic , The heater core comes out from inside. I replaced mine about 2 years ago. I just posted the pics I had on hand to give reference to where the ECM is. I had to remove the blower motor/ evaporator case in order to replace my evaporator and also repair a bad body seam allowing condensate water to run inside the passenger floor. I removed the ECM so it wouldn't get damaged or painted.
While I still have the battery out and a couple of other things, I went out and took a couple more pics showing the exact location of the connector on the 1988-91
The following users liked this post:
Remove the bolt that holds wiring harness under the blower motor the computer goes through the fire wall
Pearl Jack
09-21-2015 02:35 AM
wrd0225
05-23-2012 04:57 AM
JIMY
11-16-2004 08:12 PM
