A/C Again!!!
What are the pressures (low and high) with the switch bypassed, as well as the outdoor temp? When reading pressures, it's also best to rev the engine to about 1200- 1400 rpm. Also, have you done anything to the charge? If so, I'm thinking you may have it overcharged. Todays systems use a critical charge; too much can cause probs. Also, is there any chance there is air in the system?
An erratic/wandering high side reading indicates air in the system. Sometimes, there will be a sudden rise in high side pressure, it will stay there for a brief time, then drop back off. It's time to take a reading. When charging, don't forget to purge the air from the line leading from the bottle of freon to the system.
