Bronco II lift kit
Bronco II lift kit
Hello,im desperately looking for a 3 inch lift kit for my 1989 Bronco II. The only lift kits i can find are at roughcountrys website and its a 4 inch lift for 400 some odd dollars,which is just out of my price range,does anybody know a good website that sells at 3 inch lift kit for my truck? thanks in advance. also to be more specific im looking for a suspension lift
This is from James Duff web site: jamesduff.com
We realize that our customers have different wants, needs and budgets. With this in mind, we have developed our Suspension System in Stages--For those wanting a basic system to those looking for a higher degree of suspension performance. Each stage can be transformed into the next by adding the additional components without purchasing a completely new system each time. This way, if your wants exceed your means for now, a basic system can be purchased and upgraded later. Some items are better purchased together, like radius arms and front shock hoops but for the most part, items can be added as you choose. Please read the individual information on the upgraded components to get a better idea of the performance each stage will give.
Stage 1-Base System
The progressive rate coils and matched 70/30 shocks provide a higher quality ride, improved handling, and between 2.5-3" lift (depending on vehicle), giving clearance for larger tires.
·Progressive Rate coil springs
·Shocks with blue boots (2 front, 2 rear)
·Axle pivot drop brackets
·Radius arm drop brackets
·Radius arm bushings
·Add-a-leafs (or 1" block on Ranger SuperCab)
·Rear axle U-bolts
·Polyurethane coil pads, leveling spacer
·Lift Shackles (Explorer only)
#5023 Stage 1 Suspension, Bronco II 4wd 3" lift $425.00
#5026 Stage 1 Suspension, 83-97 Ranger 4wd 3" lift $425.00
#5028 Stage 1 Suspension, 83-97 Ranger S/C 4wd 2.5" lift $425.00
#5029 Stage 1 Suspension, 91-94 Explorer 4wd 2.5" lift $450.00
Stage 2-Coil Tower & Dual Shock Mounts
With the addition of front dual shocks and our long link radius arms, this system provides an excellent on and off-road ride, more suspension travel, with better stability and control.
·Stage 1
·Coil Tower & Dual Shock Mounts
·Shocks with blue boots (4 front, 2 rear)
·Long Link Radius Arms replace drop brackets from Stage 1
#5032A Stage 2 Suspension, Bronco II 4wd 3" lift $1050.00
#5033A Stage 2 Suspension, 83-97 Ranger 4wd 3" lift $1050.00
#5034A Stage 2 Suspension, 83-97 Ranger S/C 4wd 2.5" lift $1050.00
#5038A Stage 2 Suspension, 91-94 Explorer 4wd 2.5" lift $1085.75
Stage 3-Add New Leaf Springs
With the addition of our complete leaf spring packs, this system is for the person that wants an all new suspension system to take the punishment, yet able to provide ride quality.
·Stage 1
·Stage 2
·Leaf springs, lifted
#5039A Stage 3 Suspension, Bronco II 4wd 3" lift $1285.00
#5040A Stage 3 Suspension, 83-97 Ranger 4wd 3" lift $1285.00
#5041A Stage 3 Suspension, 83-97 Ranger S/C 4wd 2.5" lift $1285.00
Stage 1-Base System
·Rear axle U-bolts
·Stage 1
·Stage 1
·Stage 2
as of today there were two suspension kits on ebay for under $400. If you want to go cheap..go with a 3 inch body lift..which i think that's what you are refereing to..they can be purchanged for under $125. Rocky mountain suspensions is very reasonable. www.rockymountainsusp.com
Jculv
01-18-2016 11:42 AM
T_Cooksey88
12-10-2014 08:02 PM
