Harpoon The Tank?
#31
#37
#38
Go to the underground sprinkler section of the hardware store. What you want looks sorta like pruning shears but the handle ratches as you squeeze it to cut the plastic pipe. Will have a single very sharp blade. You get a clean cut quickly. Probably cost you around $10 plus or minus a couple of bucks.
Bob
Bob
#39
#40
Ditto to Satcom40's message. I did mine in a couple hours as well. The lie-o-meter read 0 miles left, so the tank was light as a feather! The fill-up was unreal! Thanks FTE and Choctaw and everyone else that contributes to this fine site.
A couple notes:
The fuel filler hoses were very hard to break loose for me. I ended up heating the metal with a propane torch and breaking the seals with a pair of channel lock pliers. Then they'd slide right off. It was a warm day too.
The sending unit 6" nut is a bear to thread back on. I had a hard time getting it to grab and not pop loose. I found I had to get it started by tapping it down around the edges, then once it was threading, I seated the unit in the tabs.
Removing the rear wheel really helps. A 2' 2"X8" on the jack pan helps stabilize the tank.
One bolt of my rear strap is unreachable because of some suspension parts. I just bent the strap under the tank and dropped her. The more empty the tank the easier this is.
I went from a 630 to a 700 miles-to-empty reading on the LOM after the mod. Fill up was much faster, but still needs some trickle at the end because of how much the diesel foams.
The only problem I had was adding fuel afterward from a yellow plastic 5G container: it leaked like a screen door, and I spilled more fuel than I added. Anyone know of a portable container that's not junk?!
Thanks to all again for the directions. This was really worth it.
A couple notes:
#43
#44
#45
I agree- this is a very worthwhile mod. Did mine about two months ago and love it. Went from 15 min. fillups to 3 to 4. Just make sure to tighten the notched fuel pump spanner real good. I thought I had mine tight, but she leaked when full. Sure enough, took everything off again and it tightened another half a turn. Presto.
PS- All I used was a sharp utility knife to cut the yellow vent tube. Went through like butter!
