Need help on engine problem
My 56 Effie has a warmed up 351 Cleveland in it. The engine has about 8000 miles on it since a complete rebuild. Lately, it has been running rough when cold (sounds like it's running on 7 cylinders) until it warms up. Then it smooths out, but isn't as crisp as it was. It also has a "ticking" sound (like solid tappets that need adjusting) when cold. That sound also goes away when warm.
Stats: Engine has a 2V heads with headers, Edelbrock intake and 600 cfm carb. Comp Cam 268H with Comp Cam lifters and springs - all stock motor after that. Compression tests good and within 5% on all cylinders (9:1). Getting fire to all cylinders. Carb and electric choke OK.
My thought is that I may have either a sticking/collapsed lifter (they are hydraulic) or a bent pushrod. I have some "Rislone" stuff that promises to loosen up sticky lifters, but before I try that, I wanted more input.
Any suggestions?
Any suggestions?
Earlier this year, my 289 started ticking on start up. My buddy is an old Ford mechanic, so he suggested adding a qt of ATF to the engine and let it idle for 5 minutes. Then change the oil. I did it and it worked. So the additive you are talking about may do the trick. Also, are you running points or electronic ignition? I always suspect points when the performance dwindles. Good luck, John
