Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-07-2004, 01:21 PM
Elemenopy Elemenopy is offline
Garage is empty, add now
Elemenopy is starting off with a positive reputation.
Arrow 12 Volt Starter
Howdy again!
Any one know where I can get a 12 volt starter for a Flathead 239? Or if I can just use the 6 volt one?
Elemenopy
Eric Wood
  #2 (permalink)
Old 07-07-2004, 05:41 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Any good auto electrical shop should be able to re-wire your 6V for 12, but it'll be spendy. I'm running 12V to a 6V starter on my daily driver going on 3 years now and works just fine. It gets started 6 or 8 times a day normally.
Just don't crank it for long periods and give it time to cool off if you don't start immediately. Flatheads should pop right off in a couple of revolutions. If not, fix what's wrong with the gas/electrical/etc.
  #3 (permalink)
Old 07-07-2004, 11:15 PM
Well then, it looks like I'll be just fine! I'm glad there are people like you around saving me money. I probably would have taken it into a shop or bought an expencive starter cause I'm a sucker. But it does takes a little while to start. Its the reason why I'm converting it over to 12 volt. My battery would die after 30 second of cranking! But there is alot of corroded wires. So it looks like I have my work cut out for me. I just did the fuel system all over. Cleaned out gas tank, replaced old fuel lines, took out some electonic fuel pump some one put on, put a new mechanical fuel pump in, and rebuilt carb. I took it around the block a couple times, but it was pretty loud cause of a couple exhaust leaks. There was that bolt broken off, and a cute (huge) hole in my exhaust pipe!
Thanks for your help and for your time with this! I'm pretty sure it won't be the last!
Elemenopy
Eric Wood
  #4 (permalink)
Old 07-09-2004, 03:03 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
Chack and clean ALL grounds. Batt to block - Block to Frame - Frame/block to Body. These Old Flatmotors like clean grounds.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
Tags
12, 12volt, 1948, 239, block, flathead, ford, rewire, starter, v8, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
