2004 F150 whine
Old 08-26-2004, 11:59 PM
BLariat's Avatar
BLariat
BLariat is offline
'04 Screw Lariat 3.73 w/ 5.4L....build date 3/04 at Kansas City WITH the whine...hmm, seems to fit in with the ones built in February
  #47
Old 08-27-2004, 02:02 PM
cajun04screw's Avatar
cajun04screw
cajun04screw is offline
Build date 2-04 kc 04screw lariat 355ls. Dealer replaced ring and pinion did not work. Now I'm waiting for ford to come up with fix. Ford will not let dealer change anything else. Just can't decide how long I'll wait before dsb board.
  #48
Old 11-02-2005, 03:26 PM
sharp4X's Avatar
sharp4X
sharp4X is offline
Red face
I have the whine at 30 to 40MPH and its louder between 70 to 75MPH. I took it to my dealer acouple of days ago and they say they cant here it!!! I also have the 3-2 clunk at down shift and they said that is normal!! I'm getting fed up with them!!!
  #49
Old 11-02-2005, 04:19 PM
DeckedoutF150's Avatar
DeckedoutF150
DeckedoutF150 is offline
take it to another dealer and see what they say. they finally put new gears in the rear end of my grandfathers truck and the whine came back. one dealer said that the only way to fix it is to put a whole new rear end in it. i just bought a new '05 and it does not have the clunk or the whine and i have a little over 900 miles on it now.
  #50
Old 11-03-2005, 12:13 PM
rcknrbn's Avatar
rcknrbn
rcknrbn is offline
Follow up
I saw this and my last input was over a year ago.
Took the truck to the dealer about 2 months ago, they installed the 'new and improved' ring and pinion gear assemby. This seemed to have solved the problem. Or so I thought.
I've noticed just this week that I hear a very faint whining beginning around 45mph. This is the same way it originally started. Right now, it is so faint it isn't noticable. If it gets worse, I'll be back in the dealer's face.
  #51
Old 11-03-2005, 08:01 PM
DeckedoutF150
i dont know what the problem is with the dealers. its like they do not want to fix the problems and then it just makes the customers angry with them. this also turns some people away from certain brands of cars or trucks, but little do some people know, the other dealers (of differnt manufactures) service departments are almost the same. when i worked at a caddy dealer as a lot tech when i got out of high school i couldnt count how many times i seen people in the service department yelling because their vehicle was not fixed. i myself have also yelled at some ford derlers service department before. then because i made them pay for the custom wheel the messed up i was banned from there and they would not work on my truck anymore, even if it was an oil change.
  #52
Old 11-04-2005, 10:39 PM
Jim Brock's Avatar
Jim Brock
Jim Brock is offline
In my opinion, the problem is with the manufacturer. They put heat on the dealership for doing a lot of warranty work. It's the "marginal" stuff that catches hell. Like my gears whine, wheel shakes, it clunks, clangs, and so on. The dealers can't ignore something that is broke, like the cab light leaks . But give them something that could go either way, the dealers will says it's normal so they don't have to fight with Ford, GM and the others.
I had a 72 Galaxie 500, new. After a few thousand miles it began to whine around 45 mph. I took it to the dealer and the said they couldn't hear anything. Knowing I wasn't crazy, I said lets take it for a ride and then they heard it. About 3000 miles later it came back. Went to the dealer and the same old story. This time I got up in the manager's face and told him it ain't right - fix it. He said we will have the zone manager look at it and decide. I told them that I will be going with them for the test drive.
Get this, I told the zone guy that the whine comes in at 40 and leaves at 50. He drove the car at 35 with the radio on and told me he doesn't hear anything. I told him to shut the radio off and get the car up to speed. He did and behold the whine was there.
The problem was with the ring. The ring was made from cheap metal and fatigued causing the whine. The mechanic called me aside and told me what the cause was and that Ford got a new assmbly from another source. He showed me the ring and the gear was near white where the pin teeth engaged. Put on over 200k on the car w/o a problem.
I recently had my message center replaced. At first it would go out then come back on. The service guy told me flat out that if they cannot verify the problem they will not fix it because Ford will reject the warranty claim. When it finally went out, no problem, it got fixed.
  #53
Old 11-05-2005, 03:09 PM
Blue Bonnet's Avatar
Blue Bonnet
Blue Bonnet is offline
all the new f-150 's seem to have a slight tranny whine at 55mph or above. i work for ford and I noticed it in my f-150(2004 5.4l).we researched it and it is characteristic an normal condition of veh. it has been doing it for 30,000 miles and everything is still fine.
hopefully everything will be with yours also.
  #54
Old 11-10-2005, 02:51 PM
sebas54's Avatar
sebas54
sebas54 is offline
Check the speed/hall sensors on the transfer case. They sometimes touch the gears inside and create a whine/siren noise.
  #55
Old 11-10-2005, 09:15 PM
DeckedoutF150
what about the ones that are not 4x4 and have the whine?? i would like to know what thats all about.
  #56
Old 11-11-2005, 08:41 AM
sebas54's Avatar
sebas54
sebas54 is offline
Check rear differential fluid.
  #57
Old 11-11-2005, 11:04 AM
Blue Bonnet
it has nothing to do with the four wheel drive its transmisision whine which unfortunately is characteristc.i work for a ford dealer and we go through this kind of thing every day. we hve checked every tsb,ssm and the like.even called the hotline. it is normal.you can change the gears all you like but it is only going to come back. nothing is going to break.
  #58
Old 11-11-2005, 12:12 PM
sebas54's Avatar
sebas54
sebas54 is offline
If the whine happens or changes during gear change then it's the transmisson.
  #59
Old 11-11-2005, 11:04 PM
DeckedoutF150
the whine only happens at a certain sleed and you hold it between those speeds, about a 5mph difference. when accelerating, or shifting it does not do it.
  #60
Old 04-06-2006, 02:36 PM
F150Texan's Avatar
F150Texan
F150Texan is offline
Originally Posted by tender_vittles
So.....how about you all reading this let us know if you have the dreaded rearend whining or not and what you truck build date is. I am thinking maybe Ford found aproblem in the assembly process early and on and the later trucks are being built withwhat ever in-line manufacturing fix they came up with. Early trucks "bad", later trucks "good". Let's hear from some more of you.
F-150 SCrew built 04/04...whine repaired 3 times with ring and pinion raplacement.
Quick Reply: 2004 F150 whine
