Question: Knock caused by phaser?
I took my truck into the shop twice now for a low-pitched engine knock. Almost like a lifter-ish sound.
They ordered a part this time called a phaser.
Something about cam adjustment.
Does anyone know more about this part, or had a similar problem and or fix?
I had to take my truck to the dealer three times for the same problem, knocking noise after warm-up. The bad thing about the whole affair is I had prove to the dealer that there was a problem and show them were the noise was coming from, at that point the dealer replaced the cam phaser and a sprocket as per the ford hot line. In my opinion ford knows about this problem and if you don't prove it to them your invoice will read like my first two did, no problem found.
Next thursday they are replacing my phaser but said nothing about a sprocket. Maybe the sprocket will be next if the phaser does not fix it, or maybe they just automatically do both at once.
Either way, at least my dealer has been cool about it.
I simply told them that ti was getting slightly louder, and that I sat in an identical 04' Ford with the same engine and it had no knock.
They gave me no problems.
Thanks
Took my 04 F150 4X4 home last weekend and after 10 miles got the same "knock" after warmed up. Posted in the forums and only comebacks were about fuel injectors (sound to dense to be that) and possibly a heat shield that didn't have the corners bent.
Since I'm working some 150 miles from where I got the truck taking it in next saturday for them to have a look.
Short story, THANKS for the heads up. Maybe this will expedite correction of the problem.
Love the truck, great ride
I have the same problem and had the the engineer at the ford plant look at me truck. I had the same cam parts replaced on my truck that masterscab did. The knock is still there. After the replacement parts were put in I took my truck to the plant and the engineer stated that the knock was still there. The engineer put a variable amp tester on the passenger cam and could make the noise go away and make it louder. The dealership and a Ford rep told me today that the noise is minimal and all the new 5.4 3 valve engines do it, just that some are more pronounced then others, and that this is just an operational characteristic of the engine, not a defect as I believe. I am now going to contact the engineer and see if what they are willing to do about this. If there are other trucks out there that do not have this noise, then I want one of them.
took my 04 5.4L into the dealer last week for the "knocking" sound(showed up after 10 miles on the odometer). They had another vehicle in recently and ended up replacing the engine due to excessive metal pieces in the oil pan!
Apparently Ford rec's replacing the phaser and associated components but this doesn't always solve the problem.
Have confidence in the dealer that they'll do the right thing and will let you know the outcome
good luck!
good luck!
