1988 E150 Conversion Fuel Pressure Issues
Old 04-05-2011, 04:46 PM
Tom108's Avatar
Tom108
Tom108 is offline
Run the vehicle at night in the dark and see if the wires have any blue sparks anywhere especially where they touch ground or each other. Also inspect the wires and look for burnt or charred areas where they come into contact with anything. Bad or old wires can cause voltage leaks which can overload all the ignition components and cause overheating and failure of any of the components, the distributor pickup, the distributor cap, the coil, or the ignition module. Also inspect the inside of the distributor cap and rotor for burnt or corroded terminals and clean or replace the cap and rotor. If you don't find any obvious damage or spark leakage here's what you can try, spray all the wires and distributor with WD-40 and let them sit for about ten minutes, this will draw the moisture from the wires and they should work for about a month if they are bad. This is just a temporary fix and the wires will have to be replaced. Just some things you can try.
  #47
Old 05-03-2011, 04:48 PM
Lady.Connoisseur's Avatar
Lady.Connoisseur
Lady.Connoisseur is offline
wow, lots of great info, hope someone can help me with my issue [see my post]...where is/are the fuel relay fuses located? being a woman, a mechanic is trying to take me to the cleaners, so would love some help here. lady dot connoisseur at hot mail dot com
  #48
Old 06-11-2012, 09:00 AM
Green Griffin 420's Avatar
Green Griffin 420
Green Griffin 420 is offline
Originally Posted by Mustang 5.0
Selector valve assy, p/n F1UZ-9B263-B $ 77.99 plus shipping from www.fordpartsnetwork.com for my 89 E-150
Will this be the same part number for a 94 F150? Mines a 5.0 with MAS air. Mine isn't dieing like others in the thread, but it does fill one tank to another. Also is there a specific part number for the sock filters for the fuel pumps?
  #49
Old 06-11-2012, 11:27 AM
subford's Avatar
subford
subford is offline
Green Griffin 420,
You do not have a selector valve on your truck.
You do have a frame mounted filer for the injectors.
There are sock filters in the bottom of each tank for the fuel pumps.
The tank that is filling has a bad check valve inside the tank. That check valve is also inside the Fuel Delivery Module (FDM).
  #50
Old 06-11-2012, 03:25 PM
Green Griffin 420
Originally Posted by subford
Green Griffin 420,
Thanks. I also want to add that mine fills both ways. if the front tank is empty and I fill the rear, the rear will slowly fill the front, and vice verse.
  #51
Old 06-11-2012, 04:24 PM
subford's Avatar
subford
subford is offline
Then you have two FDM with bad valves in them.
  #52
Old 06-12-2012, 11:47 AM
mustangman's Avatar
mustangman
mustangman is offline
i put all new rear tank,both pumps,sending unit,lines,and threw front tank in the garbage where it belongs,no more transfer valve sht, put direct 12v switch to pumps,,,ah so simple,,,do you really need more than 22 gallons? , oh yeah also replaced fuel pressure regulator with a spare one i had off a a 2.3 efi fit right in the fuel rail,the 2.3 uses the same pressure for its efi so i guess its ok, 5.0 1987 econoline runs fine with it and all systems go
  #53
Old 06-13-2012, 07:47 AM
Green Griffin 420
I thought they only had 1. Is there one for each tank?
  #54
Old 06-13-2012, 07:52 AM
subford's Avatar
subford
subford is offline
Yes one in each tank for a total of two FDM.
Look at the diagram I posted above.
  #55
Old 06-13-2012, 10:06 AM
Green Griffin 420
fordparts.com doesn't show an FDM for my truck. they show a fuel sender and a fuel pump and strainer set. Neither look like the pic above. So i'm a little confused.
  #56
Old 06-13-2012, 10:32 AM
subford's Avatar
subford
subford is offline
I can not make heads or tails out of that site either.
But part stores seem to rename the item to what they think somebody will call it when they ask for it.
They do not seem to care what the Ford shop manuals call it.
Here is one from advance:
Buy Airtex Electric Fuel Pump E2059MN at Advance Auto Parts
  #57
Old 06-13-2012, 11:21 AM
Green Griffin 420
Thanks subford
  #58
Old 02-14-2014, 07:17 PM
07terry's Avatar
07terry
07terry is offline
alternator gauge
i'm new here could you guys please help me find how to trouble shoot the alt on a 88 f-150 351 4x4 , im in the wounded warrior and it takes me a while to do the checks this is my 15 year old daughters trk we just got, has been on my wifes uncle's farm and has 100,021 miles and has been taken care of just needs some tlc and cleaning thx in advance
  #59
Old 02-15-2014, 07:54 AM
subford's Avatar
subford
subford is offline
You should start your own thread as you will get better responses.
What do you have to work with (volt meter, jumper wires with clips, ...)?
  #60
Old 02-15-2014, 08:22 AM
07terry's Avatar
07terry
07terry is offline
all and my father has a garage with lift also my brother and oldest son will help
Quick Reply: 1988 E150 Conversion Fuel Pressure Issues
