5.8 Heads on a 5.0
Over the years the 5.8 heads were basically the same as the 5.0, especially in the 80's and 90's other than the different head bolt holes/bolts required they are the same, for the most part there are differences, what is stamped on the bottom of the head under the intake ports? It should say E***? Best you could hope for on a 80 block would be E7TE they have 64cc chambers and also came out on the 5.0 HO mustangs/truck motors. There are E5TE heads they are the same except they have 69cc chambers and a larger thermactor bump but the basic ports are identical. You need washers or stepped studs/bolts to intstall the 351 on 302 heads like fordeverpower mentioned. Good luck
SwampDonkey4x4
04-23-2008 10:36 PM
lisagoud
08-26-2005 06:07 PM
