Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-03-2004, 12:59 PM
51dueller's Avatar
51dueller 51dueller is offline
2003 Ford Explorer Sport Trac
51dueller is gaining momentum as a positive member of FTE.51dueller is gaining momentum as a positive member of FTE.
Bypass Oil Filter
I have a C1BA block with an oil filter. I was wondering if it would matter if I moved the oil line from the oil galley hole to by the oil pressure hole? It is just easier to get at with the engine in the truck.
__________________
Nathan
You may have an Effie but I have a Emmie! TM
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
5.4L, AOD, Dana 70 3.73:1, Twin-I-Beam
Built to play and work hard!
  #2 (permalink)
Old 05-04-2004, 07:33 AM
mtflat mtflat is offline
Garage is empty, add now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Don't you have 3 ports on that Canadian block? And you just want to plug the stock hole and move the line to the upper one?
I THINK they are all connected to the same galley - pressure should be the same. The restrictor that regulates pressure is at the filter canister. Only possible problem you might see is reduced flow to the stock filter IF it doesn't connect to the galley, but it's not like these filter efficently anyway.
Either way, you won't hurt anything.
  #3 (permalink)
Old 05-04-2004, 01:04 PM
51dueller's Avatar
It was on the top one but want to move it to the side one.
__________________
Nathan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
