302 Supercharger
Old 04-26-2004, 03:19 PM
Sanders's Avatar
Sanders
Sanders is offline
302 Supercharger
In my quest for more horsepower I came across this supercharger. The description says it is for a 64-68 302 Mustang. Would this fit on any 302? I have a 1978 302 in a 1968 F100. Any input would be helpful, 2600 bones is a lot to spend on a part that might not fit.
Sanders
You requested a price quotation for: Paxton Novi 1200 Supercharger Kit for 1964-1968 Ford Mustang w/ Small Block (260-302 cid.) (passenger side mount - satin) [more info]
Part Number: PAX1001839
SuperchargersOnline.com*: $2,649.00
List Price: $3995
You Save: $1346
http://www.superchargersonline.com/p...ProductID=1181
Old 04-27-2004, 11:38 PM
Sanders's Avatar
Sanders
Sanders is offline
I decided I'm going to order it. I called the tech line and they were not sure but they did admit that it was a 302 and it should fit. Also they said if it doesn't fit send it back and get a refund. I'll let yall know if it works.
Sanders
Old 04-28-2004, 06:21 AM
Scopie's Avatar
Scopie
Scopie is offline
as far as i know, with my limited knowledge on superchargers, centrifugal s/c's like your paxton are basically belt-driven turbos, with the lag eliminated via the direct belt drive system. the problem with centrifugal blowers on trucks is their power *starts* at about 3000 revs, vs. a positive displacement supercharger unit like an eaton twin screw, which starts from the moment you put your foot down. torque and power down low as well as up high from the twin screw positive displacement s/c's, instead of the high paxton/centrifugal 3000-5000rpm power band.
just my thoughts.
- Sean
Old 05-09-2004, 08:05 PM
DYERS6-71's Avatar
DYERS6-71
DYERS6-71 is offline
is this a daily driver or for drag racing,etc...?
Old 05-09-2004, 09:59 PM
Sanders's Avatar
Sanders
Sanders is offline
It is a daily driver so I might not get it. I need to punch the info into the destop dyno and see what I get.
Old 05-09-2004, 10:10 PM
Sanders's Avatar
Sanders
Sanders is offline
I entered the data in the Desktop dyno and got some decent numbers. 500 ft/lbs @ 4000 rpm's and 524hp @ 6500. This is with the stock heads ported and large valves(2.1 and 1.6). 800 cfm carb and a 272 Energizer cam. These numbers are without an intercooler and running 8.5 to 1 compression.
347 stroker 550ft/lbs @ 3500 rpm's and 500 hp @ 5000 rpm's.
Interesting numbers but probably would not make a good daily driver. It would be fun though.
Sanders
tmcquick
10-19-2015 03:46 PM
frankensteined_67
08-29-2015 09:05 PM
70torino429
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-13-2015 06:35 PM
Super Duty DJ
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
08-07-2014 09:18 AM
craigibc
08-15-2010 10:14 PM
Quick Reply: 302 Supercharger
