Biggest tire size info needed
#47
#48
I have a 98 ranger xlt 4X4 offroad it had 16" by10" wide american racing rims with 245/70 16 and they fit perfect with no rubbing! I recently put a 3" body lift and went to a 285/70 16 and I have a about a 1.5" of clearance from the mud flaps when the wheel is turned all the way! I was told by my local tire shop that 305/75 would fit but I had them put one on the front and it was a little to close to rubbing so I went with the 285's and they fit perfect!
#49
#50
ive got a 2000 ext cab 2wd coil spring suspension. Front has been lifted with a 3 inch spindle and blocks iin the rear. wheels are 15x8 with 3.75 backspacing. Tires are 31x10.50x15. No rubbing. I've been playing with the idea to put on extended fenders and run wider tires but not sure yet. I can\'t go with a taller tire because its only a 2.5 engine and i don't want to regear the rearend
#51
Originally Posted by g-mann
I've got 31x9.5s on my '98 Ranger and it just barely rubs when you turn all the way, but you have to really push it. Everything is stock and its just a RWD...so its not jacked up at all. I've had these on for about 2 years and had no troubles except replacing brake pads every 6 months.
when i went to bigger tires my break replacement never changed. every 30 to 40,000 for new pads and there is still alot of pad left. The only reason i replace them is because i don't want to damage the disc so i never have it resurfaced. i'm cheap that way
#52
The wider tires might rub on the inner fender, lower corners or lower corner of your spoiler, one of those things that you just have to put them on and check and see. It might just require a little trimming with a saw on some of the plastic (like the spoiler corners) to fix that. The one thing you will notice with wider, like going to a 12" wide tire, is you will have more drag, from the wind reistance of the wider tire, and will tend to slide around a little more in the rain, but you will also notice your truck will be lighter off road......the extra width will help spread the weight of your truck out a little more.
#53
#54
#57
#59
no problem!
Originally Posted by superjfly
So is it safe to assume with a 3" body lift on that vehicle, I should be able to fit 285/75-16's? Or is that too wide for the stock rim?
Neil
Neil
#60
