Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-07-2004, 10:44 PM
Stampede is starting off with a positive reputation.
S.O.S. Motor will not turn over!!!!!
Well I think it happened, I suspect the lower intake failure. Drove the truck Monday night, hauled a heavy load of wood down to my moms, unloaded the truck, drove home. Everything seemed fine, ran good for a change, and tonight went out to start it, and the thing tried to start but just kick back, tried it again nothing, it acts like want's to, but won't. So I think a couple of pistons are full of coolant, will try to pull the plugs tomorrow and then see what happens.
Thanks Stampede.
  #2 (permalink)
Old 04-09-2004, 02:56 PM
Busa01's Avatar
Busa01 is starting off with a positive reputation.
Dude,
Thats a bummer man. I'm so glad I don't have that motor, doesn't mean it still can't happen to me though. As soon as you know something, let us know. I hope it's not that, I really do.
Tom
__________________
Stop pointing at me!!
  #3 (permalink)
Old 04-10-2004, 07:35 PM
Pulled the plugs, and the #4, cyc. closest to the core surpport on the drivers side, blow out coolant.
So what type of gaskets to buy, and has anyone does this before?
Thanks Stampede.
  #4 (permalink)
Old 04-10-2004, 07:52 PM
BlueOvalFitter is starting off with a positive reputation.
Well,its good you caught it before the engine started! You might want to loosen your oil drain plug just slightly to where the oil starts to drip from the hole.Reason being is to see if coolant has gotten into the oil,which will settle to the bottom of the pan,thus,seeing if it will drip out first when loosening the plug!
I had Ford replace my lowers back in 11/02.They used gasket #F65Z*9433*C. They also cleaned the lower intake and EGR ports.I highly recommend you do the same,if you do the work.They also changed the oil before starting the engine upon finishing the gasket replacement. If you have the extra money,let Ford do it; I had them do it due to if in the future there is a recall I have proof it was done.And,they know these engines better then anyone else.Good luck and keep us posted!
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
