v-10 engine rebuild
with proper diagnostic equipment they can be tested all at once while the engine is running by looking at the pulses on a scope. Now that your engine is out you will probably need to take them to a shop which services injectors to have them flow tested individually. There they can be cleaned and repaired or replaced and flow matched.
