2004 hood problem
Originally Posted by kfactor
Nice truck 2004 supacrewlariat.... I just ordered one almost identical to yours. Do have a web link or info on the manufaturer of your tonneau? I like the low profile of it.
Oh yeah, it also goes as fast as my hood!
I never noticed any hood vibration. I own a 4x4 Lariat and have only taken it up to about 90 and it's smooth. I travel frequently on business and have rented several 2004 SuperCrew XLT's and never noticed any problems. I actually rented several for weeks at a time before purchasing the truck. I was so impressed after putting several thousand miles on a combination of 5 different F150's that I decide to go through with my purchase. The rentals were governed at 100 but you wouldn't know you were going 100 if you didn't look at the speedo. My 4x4 Lariat with the all-terrain tires isn't as smooth as the rentals I had with the Continental tires but still no vibrations, hood or otherwise - smooth as glass.
Originally Posted by tkompass
The hood movement is at the rear edge near the windshield in the center, mine flexes up and down about a half inch at 70 mph. The faster you go the worse it gets.
I've never heard of a truck that you couldn't install a bug deflector on. Ford offers one as a factory accessory, so it should work fine without making the hood vibrate. Wind tunnels don't simulate actual driving conditions. The truck is usually sitting still in a wind tunnel.
Mine shakes enough that its actually worn a spot where the hood seal rests on the plastic shroud. Also the black moulding under the wipers (that rests against the windshield) wears on the windshield enough to form some type of whitish powdery stuff. Squeaks like crazy when it's cold. If you drive on gravel/dirt roads you'll see the hood goes berzerk. Have to say though, that the styling of the hood looks great.
Well.........................
I bought my first pickup brand-new, and about 2 months after I got it I decided to get a bug deflector installed on it (Deflect-A-Shield, I think). Right after installation, I noticed the back edge of the hood vibrating up and down at highway speeds. Also, a wind noise developed at this same time, and I can only describe it as if someone had taped several strips of paper along the top edge of the windshield, and these pieces of paper were scraping against the front edge of the roof. On top of that, my wipers started lifting away from the base of the windshiled at highway speeds. Put up with this for about a week, and I went back to the place that installed it. They said that this had happened a few times before, and would remove the deflector. Sure enough, as soon as they did, all the problems disappeared.
In the years since, I've had numerous customers with the same complaint, and I ask them if they had a bug deflector installed. Nearly every time the answer was "yes," and I told them of my experience. As soon as they removed it, their problems went away. Go figure. Just my $.02.
I have the Ford low profile bug deflector and have no problems up to 80mph. I did have a 03 Expedition with a Ford bug shield, no vibration but it changed the windflow enough that at 50 mph plus, it would sound like it was raining cats and dogs with the air bouncing off the windshield. Their solution, take it off, but I just tolerated it.
Yea, it's not uncommon for a bug deflector to disrupt air flow, causing problems with wipers, washers, and wind noise. But it shouldn't cause the whole hood to vibrate. If the hood is vibrating, it doesn't take long for those rubber tit things on the underside of the deflector to wear right through the paint.
BTW, like many here, my hood vibrates more than what I feel it should...and I don't even have a bug deflector.
#28
#30
