1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Overdrive Light BLINKING (F250 SuperDuty)
Old 02-16-2000, 07:59 PM
campbell99's Avatar
campbell99
campbell99 is offline
Greetings,
I have a '99 F250 SuperDuty Diesel with an Automatic Transmision. There is a button on the end of the gear shift which allows you to turn off overdrive -- in other words the transmission won't shift into overdrive once you press the button.
Here's my problem. I start off driving normally. I've not done nothing to the overdrive button and the truck shifts normally into overdrive. 10-15 minutes down the road, the overdrive light (which indicates the state of the overdrive button) is FLASHING. Pressing the button doesn't stop the flashing. Once this flashing starts, the only thing I notice is a much more abrupt shift from 1 -> 2 gear. Odd.
Anyone have any experience or advice?
Regards,
kc
Old 02-16-2000, 09:27 PM
Roger_B's Avatar
Roger_B
Roger_B is offline
I don't know what the resolution was, but I've heard of this symptom before.. Your ford dealer probably knows how to fix it.. I would assume theres a TSB on it.
Old 02-17-2000, 12:33 AM
V10man's Avatar
V10man
V10man is offline
The blinking light means the computer for the tranny senses a problem. Have the dealer look at it asap.
Old 02-17-2000, 01:11 AM
dad3838's Avatar
dad3838
dad3838 is offline
Old 07-02-2006, 09:00 PM
ICHTHUS's Avatar
ICHTHUS
ICHTHUS is offline
Angry
2002 7.3 PSD with blinking O/D light = $4100 new tranny
Old 07-03-2006, 06:54 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
... Welcome to Ford Truck Enthusiasts!
This happens to be an old thread, however stick around and someone will be by to talk with you.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
The following users liked this post:
Old 07-03-2006, 07:36 AM
toypuller's Avatar
toypuller
toypuller is offline
I had the same problem with my 05 F 250 that started about 50 miles after I picked it up.
Was told it was a "shifting solonoid " inside the tranny. They had to drop the pan to get to it, but it was a simple fix.
It was covered under warranty so I can't tell you what it would have cost.
Old 07-03-2006, 08:38 AM
calhounsF250's Avatar
calhounsF250
calhounsF250 is offline
my old 99 done the same thing and the sensor on top of the rear end had gone bad. it's easy to find it's right on top of the rear chunk, you have to take it out to add rear end dope, it has a magnet on the end to catch metal fragments. i know this sounds confusing but get under your truck and you'll see what i'm talking about. i think the sensor is only about 20 bucks from powerstrokeshop.com. PM me if you still can't find the sensor.
Old 07-04-2006, 08:13 AM
Casey's Avatar
Casey
Casey is offline
The only way to know what's going on is have the code read. When the OD light flashes an error code is stored in the computer's memory. A Ford specific scan tool is needed. The auto parts stores that say they will read codes free usually can't read a transmission code.
Old 07-04-2006, 08:36 AM
captchas's Avatar
captchas
captchas is offline
Guest
you need to find some one with a shop type scaner to read the trans codes. thats the starting point. not running and getting a trans rebuild . the other guys have said as it should be started every time. read the codes first.
Old 10-05-2006, 12:36 PM
critterz's Avatar
critterz
critterz is offline
did you find the issue to your overdrive problem? I am having the exact same issue with my '98 ranger. drives fine until I hit about 50-60 mph then o/d shuts off and shifts very hard when I slow down. The shift button does nothing at this point. I have changed atf, oil, filters, plugs and wires, etc to no avail....I am leaning towards the speed sensor but wondered if you got your issue resolved.
Old 10-05-2006, 01:51 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
If your transmission is shifting hard and the lights are flashing, you're driving a ticking timebomb. The more you drive, the more damage. Take it to a dealer.
Old 10-05-2006, 05:00 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Probably a bad VSS sensor at top of the differential....but as others have said, don't throw parts at the problem, have the codes read and fix it the first time.
Old 10-05-2006, 10:43 PM
Saddle Tramp 57's Avatar
Saddle Tramp 57
Saddle Tramp 57 is offline
I had same problem with F350. Tried new VSS and cleaned MAF but still blinked. New transmission - quit blinking. It wouldn't throw any codes.
Old 10-06-2006, 07:00 AM
Casey's Avatar
Casey
Casey is offline
Sure it did. You must not have had the right scan tool to be able to read Ford transmission codes.
Quick Reply: Overdrive Light BLINKING (F250 SuperDuty)
