View Poll Results: These are some ideas what do you think?
Check fuel pressure
0%
Check distributer/wires
25.00%
Vaccuum leak
50.00%
timng off
25.00%
Voters: 4. You may not vote on this poll
2.9 missing at low RPM
When shifting gears as I step into the pedal I get a miss, acts like the engine is cold, and my exhaust fumes smell really rich. This does not happen if RPM's are above 2500. I notice that on a rainy day the problem is worse. This is an intermittent problem, and I have changed the fuel filter recently. Also replaced lifters 3000 miles ago. Any ideas? Thanks!
Also check vaume. my chevy will miss, i have a bad MAP sensor on it. My ol' man gave the the advise of tearing the electronic junk off of it and throwing a carb on top, not an option with the 2.9 though. I would check the vacum with a gauge while autozone has the computer on it, and see if they are one of the same. If they are the same, and your fuel pressure is good, time for plugs and wires.
