knocking 5.0L
knocking 5.0L
My 5.0l started to knock on accel so i pulled it and found a spun rod bearing. replace all bearing and oil pump ludriplated bearing and prelube engine before startup . hooked up a manuel oil pressure gauge for good measure. started it up and the loud knock is gone but know i have a small knock at idle and accel.
I also plasigage the new baering all in spec. any ideas as to what i did wrong or what the other problem is ?? i never hered this knock before . i stoped the truck as soon as i hered the knock and towed it home. could the rod be toast or a piston pin?
cmoses
02-21-2016 06:43 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
10-27-2006 06:29 PM
