Changing to 4-bbl
on
The early -A manifold will not fit the AFB as it has the same base as the Holley and Autolite 4100 series.
The A will take the small base 4G series as well as the Carter WCFB. However if you want to use a modern style carb go buy the TransDapt #2064 at Summit, etc. The bores flow very well down to the smaller size.
the -B intake should not cost over $50 at any self respecting flea market. EBay is usually over $100 plus cast iron UPS charge. The -B flows very well, the -A is so-so.
