Oil Bath Air Cleaner
Can anyone explain the pros and cons of the oil bath air cleaner?
I was deciding on rebuilding the original carb (keeping the oil bath set up) or replacing with a new carb (or multi carb) set up without the oil bath. Wondering if I would be hurting the engine in any way without it?
thanks for any insight. Ed
And there is no reason to keep it, either, unless you are into everything being original. You have to properly dispose of the old oil when you change it. You can just throw a paper filter in the trash.
You have to clean the wire mesh filter element with gasoline or some other solvent when you change the oil. So, there's 2 contaminants you have to deal with - old oil and dirty gasoline. The paper filter does away with all that.
If you want the oil bath look with the paper filter there is a tech article on this site explaining how to convert the oil bath to paper filter while maintaining the stock look.
https://www.ford-trucks.com/articles/oilbath.php
grandpas 56
07-26-2016 08:07 PM
52flatheadf1
09-20-2015 11:47 PM
Mike-fire32
401, 477, & 534 SD Engines
06-06-2011 12:12 AM
