Engine Fail Safe Mode
Old 02-11-2004, 12:14 PM
Harrski's Avatar
Harrski
Harrski is offline
Talking Engine Fail Safe Mode
There had been a lot of discussion about the engine light comming on and the Engine fail safe mode. Alot of folks said the dealer could not fix it. It happened to me and my dealer fixed it. I posted the work order on a different thred, but figured I would start another so you would not have to search for it.
This is what the dealer did to correct the problem
EEC Tested
Code P2106
Disconnected all wheel speed sensors and reprogramed PCM per SSM 17272 and Ford Hotline
No more problems
Old 02-11-2004, 01:40 PM
Silver Screw's Avatar
Silver Screw
Silver Screw is offline
Glad to hear this fixed your problem. However, Ford must not be convinced that this is a permanent solution. I had mine in the shop yesterday and the word from the hotline is that Ford engineers are still working on a fix. I was told the root problem is still under investigation. I'll mention your story next time though... it's worth a shot.
Old 02-11-2004, 02:40 PM
splash4988's Avatar
splash4988
splash4988 is offline
When were your truck manufactured???
Old 02-11-2004, 02:49 PM
Silver Screw
10/03/03 @ Kansas City
Old 02-11-2004, 02:54 PM
splash4988's Avatar
splash4988
That's freakin weird!! My truck was manufactured around the same time and I haven't experienced that at all. The reason I asked is bacause i wanted to look for recalls. Good Luck!!!
Old 02-11-2004, 03:23 PM
Silver Screw
How many miles are on your truck? My problem started at around 4000 miles. I'm currently at 5300 miles and haven't had any other problems. A few glitches are to be expected with a totally new design.
Old 02-11-2004, 03:26 PM
splash4988's Avatar
splash4988
I have around 4800 or so. The only problem I had was the rear window rattle. I have the Lariet Screw with power rear window so I'm not sure if it only relates to that style window.
Old 02-11-2004, 04:15 PM
Harrski's Avatar
Harrski
Harrski is offline
I bought the truck 4-OCT-03. When this happened to me the truck had 3136 miles. Now it has 3800 miles and it has not happened again. I'm not sure where or when it was manufatured
Old 05-20-2010, 07:57 PM
usafhopkins1's Avatar
usafhopkins1
usafhopkins1 is offline
Check Fuse 16 , The ABS power Fuse. Mine was blown. It threw the 2106 code, Totally stumped the Dealer, And threw the ABS Light, the Parking Break Light, and The Wrench Light, and Engine light ALL ON. Replaced the Fuse. Every light went off. Truck runs perfect now.
Old 05-20-2010, 08:27 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
I hope he has fixed the problem after 6 years
Old 05-21-2010, 01:22 PM
usafhopkins1
I wasnt insinuating that He had or had not fixed the problem. But for 3 days I was looking through these forums as well as multiple other websites trying to determine the solution to the problem that I had. This thread was one of the most helpful in doing so, and thought that if any one in the future has this problem they will be very glad when they see my post above, especially if this takes care of their problem.
I was only tyring to help Bro
Old 05-25-2010, 12:57 PM
4x4fordtrkn's Avatar
4x4fordtrkn
4x4fordtrkn is offline
Thanks
I have same issue with my 04 explorer and was looking for help. thanks for post. I have to date replaced throttle body and have it at the dealer reprogramming the PCM today. will post results for future help to others.
Old 04-26-2011, 08:15 PM
626quadzilla's Avatar
626quadzilla
626quadzilla is offline
does your truck cut out and lose drive power while driving and remain idiling .? my truck is an '05
Old 05-01-2011, 09:33 PM
akder's Avatar
akder
akder is offline
05 Ford F-150 Lariet
My Ford 05 F-150 Lariet went into failsafe mode on the freeway, had to merge to the right and emergency stop in order to shut truck completely off and then restart right away. This is the second time this truck has put me in a dangerous situation. My codes are P2104 and P2111. What do you guys think, should I replace the TPS. Replace the TB unit and then flash the program with a portable unit like an X3? Thanks for the feedback.
Old 07-17-2011, 02:53 PM
masks35's Avatar
masks35
masks35 is offline
I am currently exeriencing these problems. Computer is throwing codes P2106 and P2135. I am looking into the replacement of the TPS as a starter. Or would someone suggest that i change TB and TPS and have the computer flashed? This is my the wifes car. I'll never hear the end of it if it leaves her stranded. From all i've read this seems to be a common problem on the 04's.
Quick Reply: Engine Fail Safe Mode
