97 Powerstoke hard to start
Just changed the oil and fuel filter in my 97 stroke, started up after much intermittent cranking(to avoid burning the starter) Idled it for a while and reved it a few times sounded good. Shut it down and went to start it an hour later, took about twice as much cranking as it usually ever did. If you start it immediatly after shutdown, it starts up normally, if you wait awhile it takes lots of cranking. Air still in the system?? Would working it a bit maybe clear it up?? Just wondering if anyone else ran across this before. I idled the truck about 20 min total in the driveway, i figured that would purge everthing.
