Gas to use?
What about gas.
A thought is that I didnt see any posts on what type of gas to use. Which in the case of doing performance upgrades would require generally the best gas you could buy. In the case of most posts I have read pinging and hesatation and rought running theres been that point of not good enough octane and timing is advanced to much. Edelbrocks (sp) and carter AFB carb are a general set and jet carb for so many diff engines its best to tune the carb too. Havent heard alot of good on the edel carbs and alot good on the carter AFB. An other good ad on to each carb is spring loaded needle and seat kits, they really help.
otis348
05-09-2009 08:22 AM
jnj4fords
08-16-2006 07:46 AM
new=junk
02-14-2004 05:52 PM
mypa'struck
09-08-2003 06:07 PM
