Full Floating Axle
Old 01-31-2004, 05:44 PM
FordHerrera1978's Avatar
FordHerrera1978
FordHerrera1978 is offline
Unhappy Full Floating Axle
I have a 1978 F-250 Custom,and I need to replace the rear, Full Floating Axle. In order to find another one to fit, I need to find the gear ratio. I looked on the tag on the differential, but I don't know what the numbers mean! Can anyone help me?
This is what the tag says: 3 54(1?) EDD7I(1?)A AEB
603901 2
Some of the numbers I wasn't sure of,as you can see above, because there were some rust spots. I wasn't sure if the first number four was a one, or If the "I" in the third section of numbers was a one.
Old 01-31-2004, 11:05 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Hi and welcome to the forum
3.54 is the ratio. If the 1 after the 3.54 is a L, then it could be limited slip.
Old 01-31-2004, 11:29 PM
77'F-150Mudder's Avatar
77'F-150Mudder
77'F-150Mudder is offline
Agreed, it should have 3.54 gears. But shouldn't the L be between the 3 and the 5 if it has limited slip??
Old 01-31-2004, 11:51 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
usually, wasn't for sure on the big rearends
Old 02-01-2004, 01:52 AM
Matts72's Avatar
Matts72
Matts72 is offline
On the Dana's its 354L for limited slip.
