02 Supercrew (F150) stepshields
I have been looking for stepshields for my supercrew and for some odd reason I have not found a brand that offers on for 01-03 supercrews. Does anyone know if the standard extend cabs would work, trimming them is no big deal, it just appears the angle is, which from what I can tell is about 70 degrees on the cab.
Chris
Chris
The extended cab shields will have a big bump in the middle for the x-cab latch. Putco shows #95125 to fit yours and the Expedition. #91600 Ventshade would probably fit better from an Expedition. Trenz has some part numbers but they get real expensive. All of the Supercrews I have seen have small shields from the factory so that may explain why the aftermarket did not bother with making them. If Putco's fit Expedition and Supercrew, then I would bet Ventshade does also. You will probably have to remove the Ford ones first.
Thanks for the update. You are correct by saying that the Supercrew has the small shields. For the extended cab from what I have seen they offer 4 shields. I am assuming that the fronts are larger maybe to the point where I would have to trim them which is fine. For some odd reason as of 6 months ago Autoventshade did not make the shields for 01-03 Supercrews but they do for the 04's???? strange. I have never heard of Putco but I will see what they have and give them a call. Thanks for the help.
Chris
Chris
