429 info
429 info
i picked up a429 today for 100 bucks need to know what i got and if it is a good one to build for 400 to 450 hp. also comp ratio, factory hp rating heres the casting #s block is d1ve. 8015aa head is dove-c intake is 4 dove-9425-b under this is f4 cj4 rods are c9ae 6210 hope you can help and thank you in advance
Sounds like a 70 429(possibly a 460?) Crank casting number will determine this, 10.5-1 compression factory rated at 360hp(gross). Shouldn't be too hard to make 400hp from it. D0VE heads are good castings to start with also. Block casting number is probably actually 6015-AA, rods are standard passenger car rods and will most likely do for you expected hp level (with a good resizing and ARP bolts)
Yep, ya got me there. D1=71
Originally posted by tess100
how do these stock intakes work if i use perf cam get rid of smog bumps and 2 inch open headers
