Help - Vacuum hookup for distributor advance
Oh and I check with 2 professional engine builders and they never heard of aligning bearings either.
OMG Wow you always check to make sure the main thrust bearing is aligned before you tighten that(usually the rear) main cap. It's super easy just pry the crank forward and leave it there while you tighten the main.
If you are too stupid to install the bearing in the block an on the cap so that the will fit together you shouldn't even be driving much less building an engine. This is basic bearing install stuff and is nothing to be considered special much less calling it aligning the bearing. You morons go away and play with yourselves thinking you are doing something special when in all reality you are doing basic engine building. Crap, I really hate stupid and you morons are extra stupid.
The education system is producing morons and telling them they are intellectuals.
brooklyn
26
11-09-2023 11:21 AM
RIchard Chapman
11-23-2013 10:28 PM
lazzarruss
11-20-2013 09:12 PM
svgearhead
03-04-2005 06:05 PM
