yea you should have no problem fittin 35x12.50's under there, i have a 95 branco with a 6 " susp. and i fit 35's fine until i get full articulation but that only happens when i drive ontop of a tempo and they barely rub, with that 1" spring lift you may not rub at all
On my 92 F-150, SC, LB 4x4, I run 32X11.50's on stock rims with no lift at all and I get minimal rub when turning all the way to the stops (which I hardly ever do anyway).
I'm going to put 2" taller coils on front just to level it out.
