96 F150 Heater Core
Yep. Take the seven screws off the cover and the heater core is right in there. Undo the clips for the wiring and vacuum lines at the bottom of the housing and carefully move them enough to get the core in and out. You may want to put some RTV on the cover before putting it back on to help seal it. You'll see how the factory used a similar sealant.
95' heater core
I don't know if this thread is still new enough for Intillzah or texan66truck to reply, but I have the same problem, the heater core (95"F150). How did you take the cable along the top of the panel and the wires attatched to the bottom off before removing the (heater core) panel. And the wire harness on the right side?I guess the panel slips out the bottom when all of this and the 7 screws are removed? There almost doesn't seem to be enough room for the heater core to come out.
