cruise control not working
#76
It helps TREMENDOUSLY if you completely identify what you are working on in the title or body of your post.
#77
No the dealer I bought it from is replacing the sensor/s and it's a 2014 f250 xl with the 6.7 and 70000mi
#78
Crystal
#79
To expand on my earlier post. I have seen two newer trucks where the cruise just stopped working. On one, (mine) the airbag light came on also. On the other no other lights came on. In both cases, the horn would not work when pushed. (It did work with the remote lock, however). In both trucks the clock spring was bad. We were both told (by different dealers) that this is not an uncommon problem.
So push your horn. If it works, it is probably something other than the clock spring. If your horn won't blow, I think you have found your problem.
#81
by power port you mean the one on the dash? what the heck does that have to do with the clock spring. I do not have an air bag light on. but then I have not even seen that light on when you turn on the key. I will check that. but the power port does work. like a cigarette light lighter port on the dash.
#82
Here's a twist on the whole cruise-control issue. I bought a truck with 275K miles on it. No CC. Checked everything. I had the transmission rebuilt and instantly CC worked like a charm. If my truck is pulling hard up steep terrain, it will kick off the cruise control after it has shifted out of Overdrive and can't hold speed at the next lower gear. I can't reengage the CC without restarting the truck. Also, I get a loud fan-blowing sound as the truck tries to climb grade in the gear below OD. Is there a possibility that some of these issues(mine and others) have to do with a temperature sensor on the transmission?
#83
clock spring
I also cannot find a new clock spring anywhere. might have to pull it apart and fix it if I can.
#84
#85
#87
#88
Cruise not working
Cruise not working light on dash will not even come on when turn key on. No abs light on are any other lights on as for trouble codes. Checked my brake switch and rear end switch and both check out ok. Tried the cruise system checks and get nothing on it at all using the off button are the on button when the key is turned on while holding buttons down one at a time. Checked all my fuses and all are good where do I go from here. It is a 2001 f250 7.3 two wheel drive 4 door.
#89
Had the same problem.
Change the switch at the master cylinder with this kit:
https://www.ebay.com/itm/OEM-Genuine...NZAkcW&vxp=mtr
#90
