truck wont start; frozen
i have a 1987 f-250 lariat, with a 460 c.i., 7.5 liter engine. it is about 25 degrees outside. when i turn the key it makes a clicking sound which i think is the ignition, when i turn the key, the starter(i think) clicks, and it wont turn over. THe battery is fully charged, and i even hooked up a charger to try to start it, but it wont start. Also, each time i try to start it, it clicks, dies, and it wont click back on for about 1-5 minutes like its frozen, i dont know what the problem is, can somebody help?!
Try crawling underneath and giving the starter motor a good rap with a hammer. Don't beat the living snots out of it, just a good solid hit or two on its case. Then try starting it again. This is in case the problem is a starter with a bad commutator or dirty/bad internal contacts. If this by chance does allow you to start it, realize then that starter is living on borrowed time. A short time at that!
If that doesn't do it, then troubleshooting is needed.
