Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 10-30-2003, 05:14 AM
johnanderson johnanderson is offline
Garage is empty, add now
johnanderson is starting off with a positive reputation.
Any Mi Techs In Here?
Hi, I'm in the Muskegon area (not that it matters), moved down from the soo last year. Anyway, I posted two threads in other forums that nobody has helped with. Wondering if any of you MI techs have some ideas. 1996 F250 4x4 5.8L xcab with 96K miles: 1. When real cold, say below 30, hard to start, turns over fine trys to start and cuts out, does this and you have to floor the gas. Once running it runs real ragged and then magically smooths out. Only does this cold. Done all the basics, i.e. plugs, cap, wire, fuel filter, and I let the fuel pump cycle before turning over. I think it's a sensor or something. 2. The front end (oh my god!). I replaced the ball joints and front axle u-joints last year due the front end camber (tires were splayed out bad). I have always had this clunk, pop noise when turning the wheel at slow speeds. It is most noticeable when it rains or the vehicle is wet.
Any ideas would be appreciated.
  #2 (permalink)
Old 11-05-2003, 05:55 PM
Diesel_Dummy _ Diesel_Dummy _ is offline
Diesel_Dummy _ is starting off with a positive reputation.
maybe a loose timing chain
check the front sway bar brackets where the brace bolts to the frame for loose bolts
__________________
2002 Explorer 4x4 XLS
1990 F150 4x4 XLT
2004 Ranger Edge 4x2
Mi state and ASE certified master mechanic #M236922
  #3 (permalink)
Old 11-05-2003, 09:06 PM
79blueoval 79blueoval is offline
79blueoval is starting off with a positive reputation.
Same symptoms on a 94 Aerostar
Cure was to use Wynns fuel injector cleaner(dirty idle air control)
  #4 (permalink)
Old 11-05-2003, 09:47 PM
built4wheelin's Avatar
built4wheelin built4wheelin is offline
built4wheelin is starting off with a positive reputation.
sounds like a cold fuel enricment problem. i would first look at the coolant temp sensor and next at the TPS... got any codes?
__________________
1990 bronco d60 detroit/14b detroit 5.13 39's
1968 bronco spooled 4.10 33's
2004 superduty powerstroke hauler
http://built4crawlin.tripod.com/
  #5 (permalink)
Old 11-09-2003, 06:59 AM
UPDATE
I got the cold start problem figured out. it was the IAC mounted to the throttle body. I took it off and noticed it was hung open. I cleaned it and "lightly" lubed it with light oil. The truck starts like a champ (was real friggin cold this morning).
The front end: I checked all mounting bolts, i.e. sway arm, shocks, etc. This one is a puzzler. It only clunks/pops when it's wet outside. When it rains for a few days and such. It's driving me crazy. It does it when moving the vehicle from a dead stop or driving in town and turning a corner. It's pretty loud. I'm wondering if it could be the u-joints in the front wheels. They were replaced last year with greaseable units but when I put the grease gun needle in the little hole the graese just backs out. I'm wondering if they have dried out in a year. Seems wrong to me but a guess.
Any more ideas? And what's a better way to get those pesky u-joints greased through the little hole (cannot install zerks)?
  #6 (permalink)
Old 12-17-2003, 12:58 AM
red_rocket's Avatar
red_rocket red_rocket is offline
red_rocket is starting off with a positive reputation.
I go to michigan Tech. But I don't think thats what your asking.
__________________
1989 ford f-150 35" bfg MT's, t-18 tranny, 351 W, 600 holley, 44/9" spool, rear discs.
1991' exploder sport, 4.0 5spd, 31" MT's, daily battle wagon.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
