hello all i was thinking that i would flush the old brake fluid out of my syt. i have an 95 f250 with anti lock brakes is there any tricks that i should know about thanks in advance merv
i found it to soak up everything in the master cyilinder first and then bleed the lines out and refill. other wise just bleed the brakes like you would if you were changing them
