Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-24-2003, 07:05 PM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Garage is empty, add now
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
Pics of my propane installation are up
In case anyone's interested, I've taken a few shots of the propane installation. They can be found here..
I originally had it installed in the tool box in the bed, and had used the standard 1/4" boost line, and vapor line to the intake that came with the system. One of my problems with the system was the length of these lines. With the control module in the tool box, the lines needed to be several feet long, which I suspected was delaying throttle response. By moving the control module to under the hood, the length of the hoses could be reduced drastically. Now, the line from the MAP sensor to the control module is only about 36" long, and the supply line to the intake is only about 18" long. To further increase flow, I ran a 3/8" line from the tank under the truck to the control module, and also used 3/8" line from the control module to the intake. The system originally came with a TYMAR elbow that had a 1/4" hose barb brazed on. Since I changed to 3/8" line, I drilled and tapped a fitting for a 3/8" hose barb in the metal section between the silicone boots on the intake, and went back to the original TYMAR elbow.
The result: a whole lot more output of the system, and much quicker response.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
