Pwr Str Gearbox Input shaft seal leaking - easy fix?
My 1987 F350 has an input shaft seal leak on the power steering gearbox. I am considering trying to replace this seal without removing or dismantling the gearbox. I'm hoping it might be possible to pull the old seal by punching a little hole in its metal flange and yanking it out with a small slide hammer. Has anyone tried this, will this work, any precautions or any suggestions?
Thanks.
Thanks.
If you try drilling a hole maybe...the seal is extremely hard. The chance for error ie scoring of the housing or sector shaft are high. You would then have the problem of sliding the seal over the sector shaft threading without damaging the seal. I did the job and posted my 2bits here: https://www.ford-trucks.com/dcforum/80_96/3551.html . Good Luck.
WHaynes
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in 4.10's
Detroit TrueTrac's
WHaynes
93 F150 4.9L 4x4
BFG 33in 4.10's
Detroit TrueTrac's
zwaechte
05-25-2015 07:50 PM
andysam
01-05-2014 01:46 AM
mchaffee
03-21-2010 01:01 PM
60RatRod
09-23-2007 09:36 AM
