codes P0172 and P0175
darkris,
1) Check/change your air filter. A dirty air filter or clogged intake system can cause a "rich" condition.
While your there clean your MAF.
2) Run some fuel injecter cleaner through. Reset your PCM.
If you get the codes again, have your fuel pressure tested. A bad fuel pressure regulator or check valve could be causing your rich condition.
Good Luck,
Bill
Good Luck,
Bill
jhonb33
05-01-2017 01:56 AM
JeffHann74
1997-2006 Expedition & Navigator
06-11-2016 01:35 PM
'06Roush_150
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-13-2012 06:54 PM
