12 volt conversion alternator choices
Hello,
I read an article (on the internet, I think) about doing a 12 volt swap on a 6 volt y-block that referenced a particular alternator that worked well. Now I can't find the article. Does anyone know what the good choices are for alternator/bracket combinations for this swap? I am doing this swap in a 55 f 100.
Thanks,
Jeff
Thanks,
Jeff
Hi Jeff. The place to start is with a search of the forum using the words "one wire alternator". You'll get a dozen or so hits on threads. Several of those threads go through various options and alternator types. Once you read through those, all your questions may be answered. If not, come on back and fire away.
Originally posted by jmooremtb
Hi Earl,
Thank you very much for the direction. I did the search and found exactly what I was looking for.
Jeff
Hi Earl,
Jeff
http://www.madelectrical.com/electri...hreewire.shtml
them make your choice Ed ke6bnl
