Clueless Eng Stumble
I have a 99 4.6 Expedition with 87000 + Miles. Eng stumbles at about 35MHP and 60MHP if I let off the gas then press it again it goes away untill I reach that speed again. I just put in new pulgs and wire about a month ago. Also I had it checked and there are no code or check Eng light on please give me a clue...
Fulton,
It is time to change you spark plugs and wires if you haven't already done so. Make sure to use good quality double platnium plugs, aftermarket is just as expensive as ford, so i'd recommend using motorcraft plugs. Again they MUST be double platnium. If you're paying 1-2bucks a plug they aren't the right ones. And get a good quality set of plug wires (not cheap but worth it). This should take care of your problem. I don't know how mechanically inclined you are, but if you choose to change them yourself, i'd recommend changing one plug wire and plug at a time. Once you remove the boot, blow some compressed air into the plug cavity before you remove the plug. Water, dirt, and other stuff builds up in the cavity, and you don't want that in your engine. Take your time, and I'm almost positive it will take care of your problem. I hope this helps.
Dube
Dube
Fulton,
While replacing your spark plugs won't hurt I don't think this will remedy your issue. The first thing I would do is change the fuel filter. This is easy if you know how to do. Write me back if you don't know how. If I don't check this forum soon write me at trowe76@sbcglobal.net
It is very easy if you know how to do it. You will need a fuel line disconnect tool and your new filter. You will need rags to catch the gas spilage - it's minimal - and you will need goggles to protect your eyes. There is a fuse in your power distribution box (the one under the hood - driver side) for the fuel pump.. Take this out and try to start your car a few times. If it doesn't start then you are ready to go.. if it does start let it run until it dies. Oh and last but definately not least.. NO SMOKING! Have fun. I had a problem like yours and I switched out PCV valves anc cleaned sensors and throttle body and blah blah blah.. come to find out the fuel filter needed replacing.
Stumble cont
Well I changed my fuel filter and it didnt help. Now for the first time I had a very time getting my Expy to start it had Batt power but seems not to fire after about 2-3 trys it fire and idles fine but the stumble is still there at abot 1500 rpm's. Let me add this it was colder this morning then normal but it fired up just fine firts thing it only gave me problems after I stopped and tryed about an hour later.
