Frame mounted brake booster in 56
I started out with the idea of adding AC to the 56 I purchased but it seems I keep finding problems from the previous owner/builder. I found the front brake lines were looped under the frame (hanging down about 2") so I re-routed them. Then upon further investigation found the homemade bracket holding the power booster was poorly welded to the frame and the pedal was binding so I cut it all out. Now I'm looking for an aftermarket frame mounted bracket and pedal. Has anyone purchased and installed a complete setup? If so, what brand did you use and did it bolt in? Thanks for the help.
Larry
Larry
special 55
01-27-2013 03:58 PM
rods4life
10-14-2008 06:15 AM
cjf5150
58
11-23-2006 09:20 AM
