airbag/horn
airbag/horn
Go and buy yourself a "CLOCK SPRING" for the steering wheel unit.
Little over $100.
The airbag AND the horn connect to the column via the clock spring so BEFORE disconnecting the airbag, FOLLOW THE INSTRUCTIONS for SAFE-ING the airbag, then go for it. you can do a better job than most of the parts changers at the dealer, and you don't have all that overhead either.
Larry
Little over $100.
Larry
