Air Conditioning Question
Sounds like you're looking at the amount of oil the system needs. The amount of refrigerant will vary from around 16 ounces to a couple pounds. Unless you have a REAL ACCURATE scale to weigh in refrigerant by the ounces these numbers are useless. The pressures will vary with ambiant temperature and engine rpm. Is this R12 or 134A refrigerant? Doesn't really matter much, the presures are fairly close. You could be looking at around 45 to 55 psi low pressure and around 150 to 200+ high side at idle say around 80 degrees outside temp. Like I said, these will vary with temp.
TexasGuy,
Go to aircondition.com. They are very smart and very helpful. When you post give them the High and Low presure readings at about 2,000 RPM plus the outside temp. and temp of air coming from the A/C vents. State your problem or ask your question.
http://www.aircondition.com/wwwboard/
Good Luck,
Bill
Good Luck,
Bill
TrainPRes
09-12-2011 06:08 AM
georgedavila
Exhaust Systems
08-31-2002 07:26 PM
